I need some advice on the application of the top cowl ramps [ones used to smooth airflow] I can either have the baffle sit next to the ramp OR I can trim the baffle so the ramp is above the baffle and the rubber seals against the ramp.
Either will work but would like to know what others have done with their setup.
O ,mine is a xp360 motor, straight valve .
Also I would like to leave the baffles raw aluminium but am concerned about possible corrosion. They are all done, riveted etc. Could they still be anodised?
Is epoxy coat better than paint for this application.
Once again all above will work but would like some feedback from those who have lived with these possible options.Thanks
