I am doing the baffles on my -7 and have followed the advice on the forum to fit the rear baffles to the top cowl before determining the oil cooler placement.
I used the paper clip method to check I have the required 3/8" to 1/2" clearance between the top of the baffles and the inside of the cowl to allow for seal bend and engine rock (I had to trim a lot of material??)
Having installed the left and right rear baffles I moved to the engine mounted support bracket 707D and find that it now protrudes above the baffle line and therefore cannot use the top most support hole, has anyone else experienced this. My baffle kit is about 1 year old.
Here is the picture, you can see the level that shows the cowl alignment from the rear hinge to the spinner rear plate which is similar to the cowl (inside of cowl is thicker where the honeycomb is laid), distance between top of baffle and level is under 3/4". Everything else looks fine so I cannot figure out what I have done wrong if anything. Engine is ECI 0-360 A1A.
To maintain the required clearance I would have to cut the top flange off right through the mount hole
Appreciate any input as these baffles are driving me nuts
