Scott Will
Started trimming my baffles and thought things were going swimmingly. Got the contour right on by using a huge washer and marker. I was going for 3/8 but ended up much bigger than that when I put the cowl on again. I suspect, something was off when I did the inital marking.
That being said - what kind of gap can you live with? is 1/2 or 5/8 OK? Will the airseal material be OK for that distance?
If not, I guess I can make a little doubler plate that adds some height to it.
Just curious. Want to get these things done!!!!!!!!
Thanks for the help!
