I am finishing my baffles with the aeroseal rubberized material. I have an older baffle kit (2004) and the pictures indicate I need to use lacing on some corners. No lacing was provided in the kit.
I checked Aircraft Spruce and the only lacing they have is rib lacing or poly fibre lacing. Is one of these OK or is there a rubberized heat approved lacing for the baffles?
Thanks for your help.
