briand
I went to install my right elev. to my H-S last weekend for the first time and found that one of the 413PP hinges was made wrong (looks like it slipped in the forming die or something) and the bolt hole is about .025 further aft than the other, which makes the bolt slide through on an angle. I was wondering if there is any advice? Can I just use a longer bolt and add a washer under the head to prevent damage/stress to the hinge or will I need to replace the defective hinge, I would have to use blind rivets because the skin is already riveted to the rear spar.
BTW, I e-mailed Vans about 5 times but they won't respond, so now I hope one of you guys can help.
