If you consider pop rivets as 'single use fasteners' and don't mind the idea of drilling them out and using new ones when you reassemble, they make sense.
They are lighter, faster to install and cheaper, three of the top criteria for aircraft building.
Used in conjunction with the grip washers that are made for them (previous post) you have a tried and true fastening system.
I marvel at the enginuity of some builders to invent high quality alterations to Van's designs (I have a few myself) but I always consider weight, simplicity and cost when I think about changing something.
Also, until I worked with a sheet metal journeyman, I had thought pop rivets were inferior to traditional fasteners....It turns out pop rivets are cheaper, lighter, quicker to install, more vibration resistant than a sheet metal screw, and reassembly is done with all new fasteners so you can forget about trying to keep track of the ones you removed, or if they are suitable for reuse.
The cockpit floors are a case in point here. I was all set to plate nut the floors like so many of us do, until I learned about pull rivets and considered how often I might remove the floors. I know sometimes when drilling one out they might spin, but over-all Van probably got it right (again).
