dhall_polo
rv7 tipup question...
I made a 5/8" aluminum strip to go around the inside edge of the rear plexi, as per plan. I'm about to install the rear window. (yay!) But I don't really see the value in using the strip.
I don't like the thought of tightening metal on plexi, so what I'm thinking of doing is ditching the alum strip and using one rubber and one metal washer on each screw/nut in the rear window assembly. The rubber washer would help with stress and expansion.
Any con's to not using the strip and/or using rubber/plastic washers?
