Back seat air vents
dspender
Patron
One of the back seat air vents on the side of the fuselage opens every time I fly. I have resorted to taping it shut from the outside. If this has happened with others, what was your fix?
Tighten the Hardware?
I would think you could tighten the bolt/nut that holds the part that slides during operation, to give it more friction, and hold it in place better (i.e. open or closed).
Gosh, that makes sense to me. I am picking it up from the paint shop tomorrow and I will look at that. Sounds like a simple fix.
Vent
Tip - There should be plastic washers above and below the sliding tab with the slot in it. If these are missing, it will be difficult to adjust the screw tension to get the friction set just right.
