"Lump" is pretty hard to picture, but I assume it isn't too bad. A photo or measurements might help here, but the probable answer is that, if you can live with it, so can we. If there are no cracks, things are probably OK. You might try a spoon to rub out the lump. Put a spoon on the end of your thumb and press it onto the surface and circle the lump. Keep circling, making a smaller circle each time and watch closely. Work slowly, increasing pressure as necessary and you can work out a fairly large lump, if there are no creases. If you get it pressed in past level, you can fill the depression. I don't know if this will work if there are two thicknesses of metal that are dented, but it may be worth a try. Just work from the outside of the circle, trying to make it smaller. Don't try to do it all in one pass.
Bob Kelly
