9 hours on #120264, soft start harness installed before initial start up in Oct. No engine anomalies heretofore.
Mag check normal, 40 minutes into local flight, OAT 60F, experienced slight "blip" momentarily 5 miles from field. Reduced power and got it again for a split second. Landed, checked mags at 2K rpm. With "A" switch off, engine stopped cold, came back without backfire. Tried at 3K. Dead again, shut down.
No visible damage or loose wires. Called Vans. Ken said call Rotax. No surprise here and he hadn't heard of any ignition failures execept wiring miscues prior to initial startup. Will start engine tomorrow to see if possibly heat-related problem.
In any event, I ain't flying this plane till we get some answers from Rotax. Am registered on US Rotax site.
Has anyone on the Forum except "Safety-related issue" thread experienced ignition failure...perhaps heard about another 912 crappin' out like this?
I'm hoping Rotax has a trouble-shooting procedure I can utilize; don't want to start aligator-clipping my way around an engine under warranty.
Jim N233TX
Jim N233TX
