dmattmul
I'm using 2 Earth X batteries so have temperature sensing in the BMS (Earth X panel lights installed not wired to the EFIS) along with separate thermocouple temperature sensors (Wired to the EFIS) for the batteries. Any point to wiring up the LR3C battery temperature sensors? The Earth X documentation is clear when there BMS sees an issue but I can find nothing on the B&C voltage regulator temperature sensor parameters. I'm leaning on not wiring them up. Yes, I want to make sure my Earth X batteries stay happy.
