I've tried a search and can't find an answer.
I am at the "finishing the silly little jobs" stage. One of which is to secure the axle nuts with the cotter pin. I drilled the axles as per the plans eons ago. I assume the bearings must have settled since the holes now no longer exactly line up - first problem...... I assume that you tighten as much as possible till the wheel starts to drag and then back off to the next hole - I further assume the bearings can take the minor slack since you have to allow for wear and settling etc during use.
Second problem - how on earth do you get the cotter pins in? First thing is that the 1/8" hole in the axle seems a little small and needs "easing". Trouble is, I now have the wheel in place and can't get even the smallest angle bit to it. To take the whole wheel off involves disassembling the brakes etc. Looking at it, it seems I can disassemble the wheel in situ, drill out the axle holes and then re-assemble. would this work? Having done that, it still seems that once you have bent the cotter pin to clear the wheel rim, you are never going to get it straight again to line up with the far hole.
![Mad :mad: :mad:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Any other help/useful comments appreciated before I kill something!
