I'm in the process of mounting my landing gear and I'm at the point of checking for toe-in/out. I did a search but there's surprisingly little comment on this.
With the alignment blocks against the front of the axle and a string run across I have a small amount of toe-in. The string sits off the inner surface of the block about 1/16 inch on each axle.
What's the collective experience here? Is it enough that I should order shims and try to bring in further in? Or am I searching for perfection in an imperfect world? Thanks in advance.
Bill
Bill
