I am in the process of installing the firewall forward of my RV8 build. This IO360-M1B engine comes with the Avstar fuel injection servo. From the picture, the fuel outlet from the Avstar is at the bottom instead of the common position on the top of the fuel servo as in another brand. Do you guys know of an alternative fuel outlet on the top of this fuel servo housing? Also for those who have installed this version of the M1B engine, is there an issue with fitting the cowling with the bottom mounted fuel outlet?
