dhmoose
I have spent the last few months finishing my avionics/subpanel installations on my workbench as I made the decision long ago to keep the upper forward fuselage off for as long as possible. This decision was made after my tech counselor said "get your head under my -10's panel and see what it feels like to spend time under it". The entire time, I kept thinking "Wow...this would be near impossible to do per the plans" where they have you install the avionics once the upper fwd fuse is in the aircraft.
Well, after a lot of bench work, I finally got the upper fwd fuse installed into the aircraft with avionics already installed in the panel. It then became apparent that I will still have some work to do...under the panel. For those contemplating installing the upper fwd fuse per the plans...I submit to you this picture with a warning: The image may be disturbing to some viewers
[/URL][/IMG]
Needless to say, I am thrilled that I decided to do 99% of the install on my bench....and not under the panel! As you can imagine, you can't hold this position for long.
![fgod.jpg](/proxy.php?image=http%3A%2F%2F%5BURL%3Dhttp%3A%2F%2Fimageshack.us%2Fphoto%2Fmy-images%2F9%2Ffgod.jpg%2F%5D%5BIMG%5Dhttp%3A%2F%2Fimageshack.us%2Fscaled%2Fthumb%2F9%2Ffgod.jpg&hash=b4f7288cd71321b313adf058399a3e83)
