wjb
Hi VAFers,
I'm finishing up the the substructure below the F-771 forward top skin. I have been thinking ahead to installing the avionics and would like a to make easy use of the space above the rudder pedals and below the F-771 skin. I'd like to mount some remote boxes, batteries, and other goodies up there, but I want to make whatever I mount easily serviceable and removable when the need arises.
After some though and study of the plans, I've come up with an avionics tray, 12" x 18" that mounts to the bottom of the F-745 ribs, between the firewall and the F-768 sub panel. It's made from 40 mil 2024 aluminum sheet, with hinge stock to connect the panel to the F-745 ribs and some 6061 angle for stiffening in the lateral direction:
Here's a photo of the tray in place:
Here's a side view of the hinge stock installed:
There is a very fortunate "natural" gap in the F-768 sub panel that permits easy access to the hinge pin:
Here's the view of the hinge pin from the cabin side (with the tipper raised)
The plans don't show any penetrations of the firewall above the bottom edge of the F-745 ribs, though, I'll plan a penetration for the engine monitor up there somewhere, and mount it on the plate.
The plate comes out pretty easily if you slide it to the right away from the center rudder support brace (F-6118), I should have plenty of clearance for stuff mounted to the plate.
Hopefully, this is a good idea that folks may want to consider for their builds.
If, however, I've painted myself into a corner, please let me know!
