A buddy has a Garmin GTX-327 Xpdr and is experiencing a strange situation. His avionics are all wired through an avionics master switch. When he powers up the avionics bus, all the radios turn on with the exception of the GTX 327 which then needs to be manually started. Here?s the rub- when he turns off the avionics master, the GTX 327 shuts off with the rest of the radios?
Why doesn?t it power up with them if it is on the same circuit? Is there some sort of internal setting that is required to make it power up when the switch is thrown?
