yankee-flyer
Just finished inventorying my avionics kit and skimming the instructions and I noticed that for several pieces (transponder, for example) you are supposed to fasten the backplate to the tray, fit the Xponder to the tray, and fasten the tray to some fuselage components. Although the tray is apparently a Garmin part, it's not in the avionics kit. Are these part of the fuselage or finish kits?
Also, I'd planned on having the panel powder-coated. However, the switch panel is already assembled with fuse-holders, etc. in place. Has anybody had, or considered having, that powder-coated. Or is everyone just painting the panel?
Thanks very much
Wayne Moyer 9241 N143WM
Just getting started, vertical tail finished!
Thanks very much
