yankee-flyer
I was planning to hang the engine and do the cowl fiberglass work before installing the avionics but reading ahead into section 45 it looks like the avionics must be installed before some of the cables that are hooked up BEFORE the engine is hung can be run. Did anyone do engine/avionics or is avionics/engine sequence the best way to do this?
THANKS
Wayne 120241/143WM
THANKS
Wayne 120241/143WM
