When the manufacturer says - Slide Out - Slide In, you expect that to work.....
A big heads up to save some grief for others.
When you slide your new IFD unit into the Garmin tray - slip a steel rule between the unit and the tray. When the darned thing won't screw in - try again and use the steel rule to help the draw in screw tab over so it positively engages in the old tray.
That was a lot of profanity and a couple of phone calls to realise that these new units are a lot snugger and tighter than the old unit it replaces![Big grin :D :D](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
