The MSDS states it is not compatible with Aluminum. Not sure why, but I suspect it will etch the surface.
I avoid the harsher cleaners for the airplane. No scientific reason, but there is nothing that can’t be satisfactorily cleaned with a mild solvent, rags, brush, and a little elbow grease.
Mineral spirits, Stoddard solvent (similar), Coleman lantern fluid (naptha), are pretty common solvents that I do use. Dawn Dish Soap is also a surprisingly good cleaner.
If I am near any painted surfaces, it’s Dawn all the way.
I do use CRC Brake Clean on some of my vehicle brakes. It’s easy, agressive, and doesn’t leave anything behind.
