I usually charge $250 for the condition inspection and associated paperwork signoff. This assume the owner is there to do the majority of the opening and closing, the oil change, assist with the compression check and servicing.
Additional labor runs between $40 and $55/hr depending on my mood, how much I like the airplane, what kind of work is involved, if the owner buys lunch... etc.
But I don't do it for a living either, I mostly charge these rates because it's the minimum I feel makes it worth my time. If I was doing it for a living the rates would be significantly higher. Realise that you will really be paying for expertise. You may be able to find an A&P to do it for free, but finding one with RV or at the very least experimental experience will go a long way.
