macrafic
The plans call for the the rivets to attach the aux fuel pump doubler to the firewall to be flush on the aft (tail) side of the firewall (contrary to the other rivets on the firewall, which are flush on the engine side of the firewall).
It appears from the plans that attaching the nut plates (to hold the pump) with the rivets flush on the aft side, per plans, while putting the flush side of the rest of the rivets on the forward side would allow the fuel pump to fit between the protruding shop heads on the aft side while still allowing the forward side of the firewall to remain "clean" of rivet protrusions (except for the nut plates).
For those of you who have attached their fuel pump already, can you confirm or dispute this?
Thanks.
Thanks.
