I'm installing a dual LSI set-up and have a question about wiring in the aux battery that LSI suggests:
in my system - I also have a B&C SD-8 wired to the batt buss and both LSI power leads (switched) inputs wired to the always hot batt buss. there are two separate power leads coming from the PC 680 battery to the batt buss in the unlikely event that one power lead or wire terminal should fail.
Can anyone point me to a schematic that can show how to wire in the aux batt so it is charged from the usual Z-11 scematic and then can be used for redundant LSI system power if needed.
maybe this is overkill since the SD-8 is in there too?
Thanks.
Thanks.
