Pat Stewart
Tru Trac Digiflight IIVS
My RV10 has been out of Phase 1 for awhile however I have never used the autopilot. When I installed the autopilot I had full range of motion for both Pitch and roll. I had not yet done any calibration. This morning while working in the hangar I pushed the elevator down and heard a clicking noise which led me to take the aft baggage panel out and find the source. The source was the pitch servo. I continued to move the elevator up and down trying to isolate the noise in the servo. After moving it several times I encountered another problem. The servo locked up in one direction (forward pitch) however continued to work in climb pitch.
I decided to go through the setup procedure and see if that fixed the problem. The problem remains as well as the pitch is backwards. I found the jumper instructions in the manual to fix the pitch direction issue however the locking issue remains. During the calibration the roll axis continued to try to turn left regardless of left or right input. The autopilot was professionally wired all the way to the servo’s so I don’t think its wiring.
What are the symptoms of a sheared pin and any other advice/experience would be appreciated.
