About swapping pins. I have a call into vans and Dynon awaiting their thoughts. Seemed to vans that this only affected a few airframes and a couple pins do need swapped.
Skyview with the conversion harness
Autopilot engages and calibrates but just get these network errors.
Thoughts on pins to swap? There may have an SB but i don't seem to see it.
Looking at Van's schematic SkyView-Prior-08-25-11, the OPTIONS D-Sub connector on the AV-50000A. The most likely wiring error is that pins 3 & 4 are reversed.
