I'm finally getting around to fine tuning my autopilot. I have the Skyview touch, with none of the extra autopilot knobs installed. My preliminary testing resulted in some overshoot, indicating the need to increase the sensitivity setting, which is set at the default value of 10, and shows a max setting of 24. The instructions also state that if increasing the sensitivity failed to correct the overshoot, to try reducing the gain. I thought that it might be advantageous to ask what others have found to be satisfactory settings for the sensitivity, and gain values. Hopefully pointing me in the right direction may save me a lot of wrong steps. Thanks for your help............Tom
