Problems
1. Autopilot (AP) Disconnect Switch. The AP Disconnect Switch does not operate when I push it during the servo calibration process (SkyView System Installation Guide Page 10-14), and, I can not continue with the calibration.
2. Cockpit Light. The Cockpit Light does not come on when I put on the navigation lights.
Background
I did the SkyView conversion harnesses.
Solutions ? the following are solutions I have tried on the AP Disconnect Switch:
1. Did the latest update to Dynon with the avionics and autopilot switches in the ?on? position.
2. Sent screenshots to Dynon tech support. They think everything is correct, and, that the problem lies in the AP Disconnect Switch not being grounded. When I get to the Servo Calibration screen, the two servos are seen. The screen says to push the AP Disconnect to continue. When I push the AP Disconnect, nothing happens.
3. Checked wiring on Roll Servo (aft of bulkhead) and it appears good. There is no separate ground wire at this location. Reference P44A-03.
4. Checked wiring on the Pitch Servo (under pilot seat) and it appears good. Reference P44A-04.
5. The wiring to/from the AP Disconnect looks like:
When we put the voltmeter on the wiring going into the molex connector, we found 3 volts on the yellow-green wire and 12 volts on the purple-yellow wire.
6. The AP Disconnect button does light up when I turn on the navigation lights.
7. Replaced the AP Disconnect Switch with a new one from Van's Aircraft - no change in operation.
8. Van's tech support thinks there is a wiring problem, but no suggestions on where to look.
9. Went to the screen Servo Calibration - Servo Status - Disconnect Switch, and, pressed the AP Disconnect Switch. Nothing happened on the screen.
Solutions ? the following are solutions I have tried on the Cockpit Light:
1. Did a continuity test on the light itself, and, it appears good.
2. Did a continuity test on the AP Disconnect black wire to WH B180 to Cockpit black wire, and, it appears to be good.
3. Did a continuity test on the AP Disconnect white wire to WH B179 to Cockpit red wire, and, it appears to be good.
Any suggestions?
Background
![huin45.jpg](/proxy.php?image=http%3A%2F%2Fi60.tinypic.com%2Fhuin45.jpg&hash=c99f4e99bd702a1603a1a72510de384d)
![2ptxb36.jpg](/proxy.php?image=http%3A%2F%2Fi59.tinypic.com%2F2ptxb36.jpg&hash=5c66bc27ad9ba070ea5a0c2c921b2e27)
![2hwd8gh.jpg](/proxy.php?image=http%3A%2F%2Fi59.tinypic.com%2F2hwd8gh.jpg&hash=309cc3ef88fb0226670e971541572142)
Any suggestions?
