I like the aviation plug just because
Jekyll said:
I posted this on another thread (What engine to buy) but the replies were a bit off the target of my question, so I'll start a dedicated thread here. Vern, thanks for your relevant input on the other thread.
GMCPilot George mentioned "documentation" that indicates auto plugs achieve less performance. Could you direct me to that information?
Any justified recommendations on the way to go? I read the thread on NKG plugs but that really didn't help other than highlight that replacement auto plugs are MUCH less costly.
Auto plug longevity, plug adapter reliability, electrical interference or anything else to consider? I know a lot of folks are using auto plugs and if I recall, Lycoming is now making a cylinder for use with auto plugs. I'm using ECI Titan jugs. Jekyll 7A installing systems
That is me!
"Documentation" I got you're documentation right here.
Jeky, I don't recall any documentation, may be it was documented post's I was referring to; I never saw any actual test reports I recall at this time. But let me give you some anecdotal evidence. I don't recall any reports however the cafe foundation did test the Jeff Rose's ignition.
Did you check Matronics? Post from auto plug users who had minor and some more serious problems with auto plugs. A quick check of archives, yes there has been debate and some reported issues with auto plugs going back many years. One was kind of scary and caused partial power loss. To be fair and balance, many post claim auto plugs are great with no issues!
I personally talked to Jeff Rose the original designer of the Electroair in 2004-2005. He told me he recommended aviation plugs, the REM37BY in particular. He promoted auto plugs at first but changed to recommending aircraft plugs.
Jeff also stated to me aviation plugs gave better performance, which I think he did evaluate (document). Look at an autolite or NGK. They have one single electrode over the top of the tip. That blocks some of the spark. An aviation plug his massive dual side electrodes. Which one do you think is better spark maker without any documentation? You get what you pay for?
I read one post where a guy with an Electroair went from Aviation plug to Autolite 386 and than back to aviation. He noted slight power loss with the Autolite, noting major but he could tell. His plan was to go back to aviation plugs for good. This post also mentioned a friend flying a O360 powered RV cracked two Autolite 386's in flight, causing some excitement.
This is what the electroair site now says:
"What spark plugs do you recommend? Do you recommend automotive spark plugs?
You may use either the aircraft or automotive spark plugs. There are several hundred airplanes running the EIS with automotive plugs. Additionally, you must verify that the heat range of an automotive plug is correct for your engine or you risk causing severe damage. We prefer, however, the aircraft plugs as they have been designed to work with aircraft engines and do not require any modifications for installation."
Hold an aviation plug in one hand and look at the massive metal case and massive dual electrodes. Now look at an auto plug. There is a big difference in mass. I think the aviation plug has much more potential to draw heat out of the core, electrode and cone. Heat is key to prevention pre-ignition which can lead to detonation. I can't claim an auto plug is not as good "thermally" but it seems like the aviation plug has more margin to absorb heat and transfer it to the cylinder. Also the aviation plug is more rugged and durable.
I recall one auto plug user having a miss fire at high power (temps) but it would go away when the power was reduced. It was determined the plug was getting too hot. I think lead fouling with auto plugs is from the wrong heat range, but think they may be more susceptible than aviation plugs.
Main advantage of auto plug is suppose to be cost. For me there is no questions about the aviation plug so I am going with the REM37BY. Also you don't have to buy adapters and they are more rugged.
An auto plug is $2.75 a pop and aviation plugs $19.50 a pop. That is $134 more. However aviation plugs last a long long time. Some pilots replace auto plugs every 100 hour or so. I have no idea why or if that is needed. An aviation plug I know can go quite a long time. I have no exact number for aviation plugs in hours either. The massive electrode and tip can wear down to 50% and be still be good to go. Some might say, hey there is exotic auto plugs. There are exotic auto plugs, but they cost $20 a pop or more.
Aviation plugs do have to be cleaned. Cleaning them is easy but requires a few tools: gap tool, vibrator and hand held bead blast. You can get those tools cheap enough. I use a friendly FBO's bomb test to do the visual spark under pressure test. The auto plugs are cheap so you just toss them, so that is easier. However you could clean auto plugs for more use. How long would they last? With the smaller electrode and tip I think much less.
Spark plug costs are peanuts in the big scheme of things (gas, oil, hanger, insurance). The cost difference is not that great, when you add the cost of the adapters and replacing auto plugs more often.
Sorry no Black & White one is better. I personally trust the aviation plug. Do what makes you happy. My advice is if you are a cheap son of biscuit than buy the auto plugs to save that nickle. If you want a guarantee will work no monkey motion with adapters get Aviation plugs. You know what is going to happen with an aviation plug. I don't screw with the basics if I can avoid it. There are may be a hand full post with odd or negative things regarding automotive plugs and that is enough for me. I just don't think a $2.75 auto plug has the same quality as an aviation plug. I could be way off, but that is my story and I'm sticking to it.
Good luck George
