Audio warner
Ron B.
Any listeners install Van's ES-Audio warn kit to a Skyview system and have good results. On the RV-10 I'm quite sure the stall warning switch went to a buzzer only, back five years ago at least. Now from what I can see the ES audio warn kit is some type of electronic gismo that connect to your audio system.
Thanks Ron
I installed it although I currently have it disabled. It simply outputs a warning tone that feeds into my audio mixer and then into the intercom. It works fine but i have AOA so I don't think I'll end up using it.
Chris
If I need to add something more than what is included in the Skyview system , i.e. SV-Intercom and com or display I probably will only add a buzzer.
