Attaching tailcone
JwWright57
I’ve done all I can think of and am ready to attach the tailcone.
All the fuel pumps and lines are in.
All the avionics wires have been run.
Fuel system has been pressure tested.
Any other little tidbits i should do before i attach the tail?
If you are going to fit an ADAHS unit, get thre stiffener update, and the brackets, and fit these .
Cheers
AP Servo
If you are doing an autopilot, it’s much easier to install the pitch servo before attaching the tailcone.
If it is an older fuselage kit, be sure you have complied with SB 14-12-06 before the tail cone is permanently installed -- much easier access now.
