Dwg 14 shows a pressfit bushing to 925A Brkt. This bushing as supplied is 0.25 inches long and would span the full with of FL 907 hinge bracket pair.
I suspect that Van's wants me to drill out the 1/4 inch holes in the 907 bracket to the 3/8 inch diameter of the supplied bushing.
I have certain reservations of aluminum revolving around steel or bronze bushings. I do not like the plan set up for this area. Any assistence is appreciated.
PS Bag 1789 @ has 4 press fit 3/16 ID bearings no Idea what they are for in regards to wing as the ailerons are already completed with these bearings ?![Confused :confused: :confused:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
