Ivan Kristensen
I have attached the elevators to the HS and the next step is to align and match drill the elevator horns as per instructions on page 11-3. Step #6 on that page indicates to put the elevators in "trail" position and that I will most likely find a mismatch at the bottom end of the two elevator horns.
"In trail" I take to mean that the two elevator halves are perfectly aligned to each other and that the counter balances are matched to the HS.
In making sure that the in "trail" alignment was accurate I used a laser level and to the naked eye and the laser level they are perfectly aligned.
My problem is as follows: With the above set-up in place the right counter balance is perfectly aligned with the stabilizer but the left counter balance is misaligned by 3/16" at the forward most point.
I called Van's with this problem and was told to ignore the counter balance misalignment but to maintain an elevator halves alignment.
I tend to agree with that assessment except that it bugs to see these counter balances not being aligned with the HS in the neutral or trail position.
My question to all you RV-10 builders is; have any of you experienced the same problem (Van's tells me that some of you have) and if so what if anything did you do about it?
I really would like to hear from as many of you as possible on this matter and to find out if there is a solution. Thanks in advance.
