to past QB rv8 builders..quick question...attached the wings...drop plumb lines, they all lined up (no need to adjust wings position)..measured from common point on each wing to aft fuselage point (maybe difference of a 1/4 of an inch between wings)..incidence at each wing root was 0 to 0.1 degree ..at wing tips rt wing matched wing root...left wing went from 0.1 at root to 0.2. (digital level).
Question 1...is it normal for it to be almost perfect on QB by just attaching the wings? anything we are missing?
Question 2....there really isn't anything you can do about incidence at wing tip...I mean if you try to adjust wing tip up or down will affect wing root..correct? seems like you would have to twist the wings...which I don't think is adviseable...lol
thanks for help...just trying to measure 20 times and cut (or drill) once
