jlfernan
I'm a little stressed about mounting the HS and am looking for any advice on doing this. Anyone else out there go the route of drilling the HS to the fuse with the shims in place or did you follow Vans instructions? Pros and cons to either method? Also what method was used to ensure the holes were drilled perfectly vertical?
