grayforge
Another couple roadblocks on the QuickBuild highway...
Close Tolerance Bolts Holes not aligned...
Further back for context...
- The Forward and aft Center Section Sides (F-704C & F-704D) were riveted to the F-704E & F Center Section bars while out of alignment. The sheet metal slightly overhangs the bar hole opening on one edge, preventing the close tolerance bolts from slipping in. I ended up using a dremel tool and pneumatic angle drill (for the hard to reach holes) to grind away the sheet metal overhanging the bar holes, being careful not to touch the bar holes. What a pain!
- The bigger problem: After I was able to get the bolts in, I found the forward & aft bars to be out of alignment horizontally by 1/32 to 1/16. The aft side of the spar is offset to the left in relation to the forward side. Any suggestions on what to do here? Try using a big pry bar to shift the forward and aft sections into alignment? :-(
