William Slaughter
That's my feeling tonight about the workmanship I'd seen so far on my quickbuild kit. Up to now, everything I'd looked at had been just beautiful. Just finished the wings and brought the fuselage into the shop, and it looked great, but....
I took out the rear baggage compartment pieces and got a very rude surprise! The F-862 Rear Baggage Bulkhead was hard to unscrew. When I finally got it out, I found that the center screw hole was almost a full hole diameter out of line with the others and the part warped from being forced into place. Then I saw that all three of the lower screw holes had been drilled wrong, plugged with what appear to be double flush rivets, and redrilled, wrong again. The nutplates on the F-834A and the F-834B L & R were installed by countersinking the rivet holes - in 0.025 sheet! Several of the rivets were already pulled through the sheet entirely and hanging loose, while others are just loose in the holes.
It's clear that I'm going to have to replace all of the baggage compartment pieces, and even if I can get Van's to replace them under warranty, I've still got the issue of the F-818 ribs and F-888 longerons already being "match" drilled to the existing funky parts. Now, just to add insult to injury, my digital media card reader has died, so I can't email the photos of this carnage to Van's. The excitement of finishing the wings and "starting" on the fuselage has turned to bitter disappointment.
Obviously, I'll get through this, but right now I feel about as low as a snake's belly.
Ok. Vent/Rant off.
Ok. Vent/Rant off.
