Sam Buchanan
been here awhile
2008 has seen the arrival within the RV community of two fantastic enhancements to aviation safety and enjoyment. Both of these systems rely on GPS and the internet to provide means to track the progress of our flights and the current location of our planes. The safety ramifications of these systems is obvious to all who spend a little time studying them.
Please be assured the purpose of this thread is not to promote any sort of competition between fans of the two tracking systems. It is instead a fast track for pilots just being exposed to APRS and SPOT who are wondering about the features of each system and how they would be of use in personal aircraft. This post is based on personal experience and the experiences posted by users of both systems. In the case of SPOT, detailed info about the mechanics of the system can be found on the company website. In regard to APRS, the details are considerably more scattered since it is hobbyist-based, but the VAF APRS forum is by far the most comprehensive collection of info about APRS in the aviation environment.
SPOT:
1) Reasonable purchase cost of unit ($170)
2) Requires very little knowledge of the system on the part of the user
3) Requires no connection to aircraft systems
4) Has customizable methods of tracking and notification
5) Subscription-based service ($100-150/year)
6) Tracking option uploads beacons to the internet at ten minute intervals but display on the web site can be further delayed
7) Easily removed from plane for terrestrial or marine use
8) Is a commercial venture with phone and web support
9) Dependent on clear view of sky for connection with satellites
APRS
1) Reasonable purchase cost of system components ($120-250)
2) No subscription or access fees for internet tracking
3) Based on hobbyist use of 2-meter Ham radio band
4) Requires possession of Amateur Radio Technician License
5) Requires some degree of geekiness on part of operator
6) Provides practically real-time internet tracking down to ten second intervals
7) Usually is installed with some interconnection with aircraft electrical system
8) Is not easily removed from aircraft for terrestrial use
9) Dependent on population of land-based digipeaters and iGates for coverage
This list can be expanded with further details (and replies will not doubt provide additional info) but should provide an overview of the two systems.
Based on my experience, here are some observations which other users of the systems may or may not share.![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
1) For the pilot who has no interest in "hobbying" or learning a new interest, SPOT will be more easily added to the aircraft and implemented since the device can be simply "thrown on the dash" of the plane
2) For the pilot who wants to avoid subscription fees, APRS will provide the lowest ongoing cost for tracking service
3) The pilot who wants commercial support in all aspects will probably need to consider SPOT
4) SPOT may guarantee coverage over a wider area as long as the device can "see" the sky. However, field history is demonstrating the APRS network is very good in all but a few isolated locales.
5) If automotive or marine tracking is desired from the same device, SPOT is the more viable option
6) The highest degree of resolution and accuracy of aircraft tracking is available from APRS. SPOT is limited to ten minute tracking intervals which in RV time could be as many as thirty miles between beacons. APRS can beacon every few seconds in maneuvering flight which can pinpoint the location of the aircraft to a very high precision. SPOT does provide the option of sending a discreet beacon if the pilot is capable of doing so.
I hope this discussion is helpful to those exploring tracking options. The benefits of APRS and SPOT tracking are readily apparent and should become more and more popular as they penetrate our aviation community. Both systems were designed with terrestrial use in mind, but I think their greatest value may turn out to be in the aviation world.
SPOT:
APRS
