Thanks, that is helpful that your GX 50 worked with the D10. At least now I know the d100 will get some gps info. Also did you use an OAT probe with the D10 or you just using the gps info? Still need to know if going straight from the GX55 to the d100 will display CDI info as well.
Bobby
