Hi all,
I'm helping a friend with an AP disconnect problem. The autopilot will not stay engaged and gives a "disconnect switch locked" indication on the EFIS. We think the button itself is OK since we disconnected the molex under the panel and get the same indication. The button is supposed to ground a white wire to the servos to disengage them when things are working correctly. It appears there may be a short to ground somewhere. We are going to do some continuity checking and I would like to know where an ES-00019 connector shown on the elec. diagram is located. Does anyone know where this connector is located in the SV wire harness? It might be adjacent to the ES-00057 d-sub AP connector or even in it's backshell?
![i-2dPjJ9Q-X2.png](/proxy.php?image=https%3A%2F%2Fphotos.smugmug.com%2Fphotos%2Fi-2dPjJ9Q%2F0%2F2083f2d0%2FX2%2Fi-2dPjJ9Q-X2.png&hash=c13c4167298190d7a8c8007f833f9827)
