sstellarv10
Just about ready to install the stall warning vane in my wing and I am thinking about using the AOA system by Advanced Flight Systems instead. Is anyone using this or any other AOA system and what are your thoughts.
I'm planning a G900 EFIS, I guess I should check to see if the AOA is included with the system![]()
Is there a reason you HAVE to install the stall warning vane? Any FAR's or such? Thanks.
I'm still dreaming about my RV, but the reason I plan on installing an AOA system is for a back up to the Pitot/Static system. If icing (or bugs) blocks my pitot tube then I still have an excellent way to gauge airspeed during approach and landing. On planes with large gross wt. changes the approach speed is calculated for each landing. However, the AOA will always be the same (assuming the same amount of flaps are used).
There are no ugly probes to slow you down or collect ice and no moving parts to break.
Here's a bunch of thoughts in no particular order:
* AOA is a great concept when maneuvering near the ground at low speeds. The real question is whether a visual display is appropriate when you're mostly looking outside, i.e., when you need it most. My opinion is that an aural stall warning with multiple sounds, sort of like a Cessna reed-style system, has the most potential, especially if it is calibrated to give warning of a too-slow approach that can lead to a hard landing.
* AOA can be great for maintaining optimum AOA for long range cruise or for Vy.
* I've read what I consider a lot of hype about AOA. I think that the concept has merit for some things, but , for example, AOA won't tell you when to rotate on takeoff.
* I've not read anything about how you use AOA to reduce your susceptibility to gusts on short final. There are plenty of formulae for airspeed, by comparison. Having a device with no procedures for using it and just saying "it's wonderful" is nonsense at best....
* At Boeing, many customers were excessively on the AOA bandwagon. Boeing eventually had several of its most senior and most respected engineers write an article to bring sanity to the discussion.
* Over the years, I've tried several times to write an article on AOA, but when I started asking the hard questions, vendors had trouble finding me an airplane to fly.
My opinion? I think that most of the value of AOA is hooked up to a variable sound aural alert. I like having it as a secondary indicator for Vy and optimum AOA. But, having flown a number of aircraft with no stall warning system at all, I can (and do) get by without it. And it's not clear how much operational advantage there is to holding precise AOA for Vy and long range cruise for the operations I do.
Ed Wischmeyer
(lotsa good letters go here)
