So its purely a stall warning device? You can't use it to fly AOA vice airspeed?
The GRT AOA indication is very different from all the rest - it has no sensor, but is "derived" with data from the attitude platform. While I am not convinced that it is useful in aerobatic flight (things happen too quickly for the computational cycle), in the kind of (relatively) steady state flight you do in the pattern, it works quite well. You do fly calibration routines (slow flight, decelerating flights to a nibble) to get it to "know" your airplane.
Paul
A calculated AOA is very tempting as this means it does not cost us any hardware, no extra pressure sensors and electronics and of course it is easy to install - you don't do anything...
Rainier
CEO MGL Avionics
And everybody KNOWS that software is free, right Rainier??![]()
You are sort of thinking in reverse on this issue.
AOA really doesn't need calibration per se as it is a physical measurement of the angle between relative wind and by convention the cordline of the wing.
Whatever device you are using (wind vane, or Dynon Pitot probe) the measurement is direct. You don't even need to know the true angle you could call it units if you like.
AOA doesn't map consistently to airspeeds across the range of possible Gross Weights and Density Altitudes for your airplane. The airspeed values of Vs, Vs1, Vx, Vy will be different for each GW and DA combination but those performance indicators occur at the same AOA independent of GW and DA- hence the benefit of an AOA instrument. If AOA mapped to Airspeed across the spectrum of GW and DA then what would be the benefit of an AOA indicator as it would simply be the the same as your airspeed indicator with a converstion to degrees or units?
The process of noting when the stall occurs is merely to provide the set point for the warning. You'd have to do the same thing for Vx and Vy by flying those profiles and noting (mentally or electronically) the AOA in which they occur. But the AOA itself needs no calibration rather you just need to determine what AOA results in Vs, Vs1, Vx and Vy and fly those AOA's when you need to.
Make sense?
Ken
I get what you are asking now..
Yes, you can fly AOA for all those points just like in the F-18 once you know what they are.
Are you familiar with Sawtooth patterns for climb performance determination?
nothing special really but you'll use your altimeter and a stop watch and not the VSI to determine best climb/descent profiles since the VSI has too much lag and is not accurate enough (generally). You'll establish a steady-state climb and descent throughout a range of airspeeds (5 mph increments works well)
Set a reasonable altitude band of about 2000' (say from 2000-4000ft PA). Start about 500 ft below the target altitude band and trim at an airspeed about 5 mph above your Vs1 speed and initiate a full power climb and trim to maintain A/S +- 1mph. As you hit the lower altitude start your stop watch. Record: MP,RPM,A/S,AOA,VSI,OAT,ALT Band, Time to climb, fuel. Pitch Attitude.
Do same thing for the descent and start over at next higher A/S. Repeat until you've covered the A/S range you are interested in. With all the data you can use excel to calc to plot or calculate the data for the parameters you are interested in. The one caveat though is fuel burn changes your gross weight and will skew your data as you move up the A/S range. If you do it quickly it will be in the noise. In an F18 though you'd have to use what is called the referred weight/sigma method and use math to eliminate weight and DA as variables...its not hard but requires a lot more work.
If you do this method throughout the entire A/S range at very light weight, mid weight and max GW (under similar test conditions) and at low, med and high altitude bands you can then develop climb/descent charts through interpolation. Takes some time but is worth it.
How do you calibrate these systems to your given wing design? That's more what I was getting at.
Each manufacturer has instructions for calibration, but it's obvious that they only consider it a useful tool during approach - because they blank out the info at the faster speeds.
