AOA/Pitot
olderthandirt
Wondering if folks have been using the the AOA/Pito probe from Dynon rather than using the pito in spinner on Rotax setup...reason for asking is, if this was used then prop/spinner change would be easier/less complicated?? Also are you using hookup kit from dynon?? And the mounting kit from other vender?? Dick
I added a Dynon heated pitot/AOA to the wing of my -12. I used a SafeAir pitot mast and quick disconnects to keep wing removal and installation fairly simple. Not sure how it compares with the spinner pitot for maintenance access, but it is a lot more work to install and plumb the Dynon pitot. I have seen several good examples of doubles/mounting brackets by other -12 builders, needless to say if the wing skins are not on you have a lot more options for brackets and plumbing conduits.
John Salak
RV-12 #120116/N896HS
