Or as I describe it, "the one that pokes up above the motor a little bit." If so, are there any issues with clearance on the cowling? Fixin' to mount the motor so I'll be able to figure out the clearance on everything under the hood but not the cowling quite yet. I have the test items from B&C so I can get a pretty good measurement on the height.
I know about the tach cable interference...but I have dual P-mags so no issue there. Also looks like the oil cooler return line is clear as well.
Thank you!!
Thank you!!
