Gash
I'm considering getting the Plane Power FS1-14 30 amp standby generator to mount on my RV-8's IO-375 with 90-degree oil filter adapter. I like the idea of 10 more amps (compared to the B&C SD-20) and the fact that I won't need the LR3C voltage regulator since the Plane Power model is internally regulated.
Is anyone using this new Plane Power standby alternator with their RV-8? What size spacer(s) do I need to avoid conflicting with my 90-degree oil filter adapter on the IO-375? Thanks very much.
