Using the vacuum pad is one place to pick up oil while inverted, many systems use the breather line with a "T". B&C sells a vacuum pump drive adaptor that has an extra tube /port for inverted oil pick up while still using a SD8 or other device being driven on the vacuum pad. I have had all three locations for inverted oil pick up and can truthfully say they all worked equally well.
