jab 5100cc 8-cyl.
I flew that aircraft a couple of years back. In comparison to my 180hp Lyc Rv-4, it was real smooth and hassle free to operate. Choke, turn key, purrrr, and no mixture to adjust in flight (2 x Bing CV carbs tailored to the engine). Performance seemed typical of a 180hp RV-6, but I didn't get any hard numbers. The engine is longer than a lyc, and you can' t use a CS prop. or fit a standard inverted oil system.
Jabiru started development of the engine and firewall forward package when the Aussie $ was down below 60 US cents, and before the Lyc-clones became common at less than Lycoming list price. Once this changed, the economic motivation dissapeared. Jab haven't built new ones in a while, and earlier this year were advertising old stock at AUD$20k. I'd seriously consider one for a light, simple RV. Without expert knowledge, I'd say the 8 smaller cylinders running at higher rpm would make it less prone to detonation and thus more suited to mogas use than a Lyc (the factory recommend avgas only however).
