Brdog42
Yes, no?
I?m rebuilding an -6A which had an engine failure while in the pattern 15+ years ago. 250 TTAF. Jim, the owner/pilot, my IA & former co-worker, was able to land on the runway. The only damage was a seized IO-360 angle valve the original builder installed. Jim was the second owner. The airframe sat in the back corner of Jim?s hangar until last August. He also had a new IO-360 parallel valve in a crate and a new engine mount/nose gear. The original engine needed a different mount.
So, now I?ve this -6A in my hangar with that crate IO-360 & engine mount. Jim passed it on to me. I?ve hung the engine and added baffling. But nothing else... no fuel lines, throttle/mixture cable, etc. It?d be the time to add the new nose gear.
I?ve basically a super quick build kit with an Airworthiness Certificate. A clean slate. The interior is completely removed. No instrument panel. I?m still not sure where I?m going with it. Mostly day VFR sightseeing trips for friends around AZ. I fly IFR at work and don?t feel the need to fly IFR in the -6A. Not with the IMC conditions we get in AZ, anyway. The -6A will be better with our DA?s than the A150L. Although I miss that Cessna.
Tim
Tim
