I am in the process of buying an IO 540 C4B5 engine. The seller also has a prop that was used on this engine. The prop is HC-C2Y(R)-4CF and the hub model D-2201-16. I spoke with Hartzel, and this an aerobatic prop that goes into course pitch with loss of oil pressure (not feather). It also has counterweights. I am still finding out about the blade numbers. The Hartzel rep said there is no problem using this prop for non-aerobatic application, but installation might prove difficult. Has anyone installed this type of prop in -10? Or on any RV model?
Thanks.
Johan
Thanks.
Johan
