Anyone install Notification 18-04-06 Alternate Regulator and Cooling
Vans Hektik Kit
I recently installed the kit, works well. Install as directed ,no problem. The edges need trimming on the tiny lines, the lenth was perfect, my cable barely touches the duct so I didn't trim. Use Flox and rough up both surfaces before attaching. I did use new electrical connectors to the unit. Works Great!!! Keep the cowl to NACA scoop edges sharp, except for the small front intake. Ben N40BF RV 12 RV 7A . I will suggest installing the regulator first so you can locate the duct properly.
